Newb question about sub, amp, and wiring.
DrewsZ
I have a 2008 Suburban LTZ with factory nav and Bose. I want to add some subs. I am thinking about going with some 10's bacause I want to keep as much storage as possible. I would like your expert opinions on some items I picked out already. Will this amp and subs work well together? Will I be able to get the amp down to 1ohm? Will this sound processor work with my factory system?
Thank you.
Amp:
Audioque AQ2200D
Subs:
Image Dynamics IDMAX10 V.3 D2
Sound processor:
AudioControl LC6i
Box:
Something custom made with help from these forums.
Extra battery:
BatCap 2000 or
Kinetik HC2400
I have a 2008 Suburban LTZ with factory nav and Bose. I want to add some subs. I am thinking about going with some 10's bacause I want to keep as much storage as possible. I would like your expert opinions on some items I picked out already. Will this amp and subs work well together? Will I be able to get the amp down to 1ohm? Thank you.
your factory amp isent gonna work for subs. and no its not gonna work at 1 ohm
amp going down to 1 ohm depends on what amp your gonna use and if its 1 ohm stable, just get 2 d4 subs so you can wire down to 1 ohm. maby some SA10's
I have a 2008 Suburban LTZ with factory nav and Bose. I want to add some subs. I am thinking about going with some 10's bacause I want to keep as much storage as possible. I would like your expert opinions on some items I picked out already. Will this amp and subs work well together? Will I be able to get the amp down to 1ohm? Will this sound processor work with my factory system? Thank you.
Amp:
Audioque AQ2200D
Subs:
Sound processor:
AudioControl LC6i
Box:
Extra battery:
BatCap 2000 or
Kinetik HC2400
That all looks pretty good OP... Look into the MS8 processor instead though...
Need an alt if you wanna run 2200 watts
I'll bet you money he doesn't //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Open ignore these trolls.....your list is fine...except that AQ amp is only 4 ohm stable .
The website says its 1 ohm stable.
This is from the site:
The AQ2200D is fully stable down to one ohm.
Daisy Chain connection of two AQ2200D’s stable down to two ohms
Four way protection circuits: Speaker shorts, DC offset, High/Low voltage, Thermal protection
High current MOSFET switching devices
24db/oct slope crossovers, Fully adjustable Low Pass Filter and Subsonic Filter
Dash Mounted Remote
DrewsZ
DrewsZ
Belle Vernon, PA
Bettr n' Revrse
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
