Newb, looking for suggestions on a 10" sub and an amp
  • 4
JasonK94Z
I have been lurking around and decided to finally register and ask a question today. I recently purchased a new Ram 1500 quad cab. I am getting ready to build a custom fiberglass encosure in the storage area underneath the passenger side rear seat. I am guestimating that I will have .60 to .70 cu ft volume, sealed enclosure, firing straight up.
I will keep the factory head unit, and I have already replaced the front door midbass 6x9's and dash tweeters with Kicker. The Kicker kit came from Mopar, had the right connectors on them, and they fit in the doors properly (I got them dirt cheap). I also repalced the rear door 6x9's with 2 way Kickers, again from Mopar and dirt cheap through a friend.
I am looking for a good budget 10" sub, and an amp to run it. Amp needs to have speaker level inputs, or suggest me a converter please. Would also be nice if it had a remote adjustment for sub volume. what about runing a svc 2 ohm sub to take advantage of more power available from the amp? Is it possible to keep the price under $250?
Thanks in advance for any advice, where to buy, etc.
Edit - listen to rock, sometimes bass intensive. Also, no more than 6" of depth available.
New ones still have the difference between the passenger and driver's side "wells?"
(On my 08, the driver's side is larger)
I am able to get at least 0.69cube with 12s, so you should be good to go on a single 10 if you glass more than just the well, esp on driver's side
MSW | Car Audio Stereo, Car Subwoofers, Car Amplifiers and Speakers
So with that amount of airspace, an 8" sub will outperform a 10"?
Being a newb, whats eg and loc mean? Sorry, lol
EQ=equalizer ; LOC=line out converter
You will be fine with 10...plenty of space to glass besides just the "wells" that will allow for install of even 12s
The difference between the passenger and the drivers side space is negligable. Nice to keep the drivers side open to be able to use without walking around the truck all the time.
Understand your desire to keep the driver's side open for use, but on mine the diff was as much as 0.2cube....not "negligable" when you're talking about only having 0.6-0.7 to work with
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
You may or may not like the sound of just dropping into the stock locations but loading into the glass is definitely going to cause some issues...
15
JasonK94Z
JasonK94Z
Olathe, KS
JasonK94Z
    May 22, 2024
    May 22, 2024
