Newb in need of help.
bmf85
Hey all!
As stated I'm a newb, to the forum at least. And, just recently diving back into the realm of car stereos after a fairly lengthy hiatus.
Anyway, I recently acquired an old school AudioPipe GD6001 for stupid cheap. When I got it, it was covered in dust and cob webs so I didn't even attempt to power it up. I took it home, blew it out with air and tried to power it up when I started to smell the lovely Fet burn.
Upon opening it up I see 1 very burnt IRFP064 and corresponding resistor on the board. After further looking it appears what I believe to be the 4 drivers for those Fets have been replaced also and the ones currently installed are FMG32R.
The smaller Fets seem to be in working order but are a mix of IRF9640 and IRF640 with some having been clearly replaced since manufacturing, some not.
At the very end of the board on input side is a KIA7812A and a KIA7912PL
On the output side there is one KIA7915P and one KIA7815A.
Wondering if anyone has a schematic for the board or can just tell me what fets/drivers SHOULD be in there as it looks like someone did some replace only the 'bad' repairs. I plan to remove and replace all Fets, drivers and gate resistors as a project to learn more about fixing amps. Ive got a decent knowledge for electronics and how they function and am a proficient solderer.
As soon as I get the board fully removed from case I will post photos.
Thanks in advance!
As promised, pics.
Once I had the board removed I noticed a couple of suspect Caps as well. There seems to be no damage to the board itself or anything other than the 2 caps, one fet for sure and one resistor but as stated I plan to change all fets and corresponding resistors to be safe.
Left to right the photos are.
Fried Fet
Entire board
1 suspect cap
Other suspect Cap
It appears someone failed a repair, which is worse news. Looks like they only replaced the failed parts without discovering the real problem.
Have you purchased the Amplifier Repair tutorial from BCAE1.com? If not, I recommend it before going further.
Rich V.
That, essentially, was my assessment as well. I fully intended to do fill diagnosis but was hoping to learn the original Fet/driver numbers in order to order them as I plan on replacing all of them as should have been done originally. I'll look into that repair book, thanks.
bmf85
bmf85
Spokane, WA
bmf85
