New with amps - help appreciated
blaked33
Hey guys pretty new with all the car audio
I have a Memphis mojo5 12" (1ohm stable) in a 1.65c box ported
I need some inputs on what amp I need
I have a extended cab 2012 Tacoma if car size makes a difference
Would a Memphis prx1.500 work? Or not enough? Neighbor has one - very cheap
All help is greatly appreciated! Thanks
Sounds like the 15-mojo512d2, right?
It's 1100w rms. You don't NEED 1100w, but considering you have a $450 sub I would expect you'd like to at least have the ability to bring it to life when you want to.
So while 500w would work, I would go with something closer to 1000 at 1.
If you want to stay with Memphis the prx1.1000 would be the obvious choice.
But there are plenty of other good options that will be much less expensive.
Soundstream RUB1.1000D Rubicon Series 1000W Class-D Monoblock Amplifier
Pioneer GM-D9601 GM Digital 1200W Class-D Monoblock Amplifier
Rockford Fosgate R1200-1D 1200W 1-Channel Class D Prime Series Amplifier
MB Quart RA1000.1 Reference Series 1000W Monoblock Amplifier
SKAR Audio LP-1000.1D LP Series 1000W Class-D Monoblock Amplifier
blaked33
blaked33
Mt. Airy, NC
n2audio
michigan born
    May 14, 2026
michigan born
    May 14, 2026
