SocMunky
What happened in here?
- Thread Starter
- #16
i have a 94. i have 3 jl 10w0's right now and they are loud. i have had 2 infinity 10's, 1 10"L7 and a 12" type r. they all sound good. issues you will have are the rear deck likes to rattle where the 3rd brake light is, trunk rattle is hard to get ride of same with rear bumper rattle. i am gonna try a down firing this next time. for running the power wire you assuming it is like mine which it should be all they did was change dash and body lines, you can drill drivers side up high next to the brake master cylinder next to the large wiring harness, or there is a gromment midway up on passanger floor board. i drilled because it is a more direct route. alarms are easy on them too.
What gauge wire did you end up running to the back? I still need to do the calculations for mine and figure what I need to run.....
Alarm does seem easy so far, mounted the brain right between the radio and the instrument cluster, theres a perfect spot for it right in the middle.
Hopefully I won't have too much rattle to deal with, only gonna be running 1 10. We shall see. Maybe I'll bust out some edead on it if it does.
