new to the car audio world and need some help
///nick
hello, im new to the whole car audio thing but i happen to know a few things. anywho, i just bought some new subs and im having this burn smell come from the ported box. smells sort of similar to when i blew my jbl gt4 12's.
here is the set up i have
2 RE audio srx 12'' each sub is wired to run 2 ohm and both speakers are bridged to one channel
fairly big ported box
jbl 1200 watt mono 2 channel amp
4 gauge power wire with 100a fuse, everything is hooked up legit.... i hope. ive double checked everything
this kind of ***** because i just bought thease subs. any help would be great! thanks guys!
these statements are telling me that you may have your subs wired wrong... or more than likely your gains set wrong, and killed your subs with clipping.... what impendance are you running your subs, and how did you tune and set your gains? how was everything done "legit"?? explain a lil
ok well i ended up getting a new amp. its a kicker zx1500.1 and its making the same burn smell. i had the gain set at 25% bass boost turned all the way up, xover freq turned all the way down. on the deck i have volume at 45 to 50, bass turned all the way up (6) loud setting on high. just re did my settings on the amp, turned bass boost to half, and turned gain up to 45%. i just want my subs to run at full potential without blowing up. i upgraded all the wiring to 0 gauge, big 3 upgrade. and im about to buy a 4 farad capacitor tomaro
so what i did was play some white noise with my eq on flat, no bass boosts or anything. volume 30 and i turned the gain up just to where i could hear the bass. i also set the xover freq
///nick
///nick
Washington
///nick
