vnyborg
I posted this in the general forum as well. Not sure if its cool if I post my question here too.
I have an 06 accord that ill be keeping everything stock inside, as far as the head unit and speakers.
Will be using a line out converter(I ordered AudioControl LC2I) and 4 gauge wiring kit.
Now I need help on two things. I decided to go with an 8 inch sub because i don't want to take up too much space in my trunk. Having a hard time deciding which to go with, here is what I'm looking at.
Infinity Reference 860w
Alpine Type R
JBL GTO
Kicker C84
I was considering Sundown SA8, TC Sound Epic 8, and Image dynamics. But I don't think I want to spend was these are going for. I'm still on the fence though.
The second question is I have an older amp that a friend gave me, I tried looking up info on it. But I came up with nothing. Will this amp be a good choice to run? Will it be worth keeping? If not, what you would guys recommend?
View attachment 26550360View attachment 26550361
2-Channel, 1400W Peak Power Amplifier
24Db / OCT. Crossover Shape
Variable Subsonic Filter (10Hz - 100Hz)
Variable Low Pass Filter (30Hz - 500Hz)
Variable High Pass Filter (50Hz - 1kHz)
Variable 18Db Bass Boost
Tri-Speaker Hookup
High & Low Level Input Through RCA
Dual Protection (Thermal & Circuit)
Double Sided PCB
2 Ohm Stable (Stereo)
Soft Delayed Power On
Power & Diagnostic LED Indi
Alpine Type R
JBL GTO
Kicker C84
Tri-Speaker Hookup
Double Sided PCB
