New test..IA 20.1 vs. Kicker ZX2500.1 vs. Orion 2500D
in this particular test....
Kicker
Orion
20.1
Its proven that the 20.1 isnt an outstanding daily amp....It shines at really low impedances. And this setup is a Daily Driven Comp setup, and Orion and Kicker have proven time and time again that they are superior daily amps....now on the otherhand Drop the impedance down lower than .5 ohms and the 20.1 will hand The Orion and Kicker their *****.
If this test is not done as a bench test would. All results are null and void. You need a stable testing environment to be able to extract viable outcomes...
It will how ever give a practical application estimate.
which is truly more useful then a stable, uneffected voltage supply.
Kicker
Orion
20.1
does anyone ever read what the original poster posted???
he said his gonna test the ia and the orion at .5
and the kicker at .5-1-2 ohms.
The same can be said going from the bench to various vehicles.
True, but isn't that common sense. That a bench test is only to show what the product is actually capable of producing in a install, perfectly matching the test environment? Given the correct current and impedance vehicle responses can be accurate with the bench.
I would imagine the original poster will be posting the information, in hopes of pointing out the stronger/better product. Which will not be accurate.
I said Lower than .5 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
IA will out do the orion lower than .5 but the Orion will probably out do the 20.1 at .5 especially if he doesnt have the juice to keep the voltage up.
any results yet? kicker zx ftw //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Well here are the results
clamped the IA @ .5 ohms again.
did about 1800 watts with a 2.2 ohm rise
the Kicker @ 2 ohms did abouit 1500 with a 8.9 ohm rise //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
the Kicker @ 1 ohm did a 2150 with a 4.3 ohm rise and was 90% efficient..and yes we did the math
the kicker @ .5 ohm did 2550 with a 2.2 ohm rise //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
and i metered iwth the kicker @ 2 ohms and .5 ohms with 2 subs, and 1 ohm with 4 subs
2 ohms - 147.9 on 2 subs
.5 ohms - 149.9 on subs
1 ohm - 151.2 on all 4 subs.
so IMO overall...
thet Kicker takes the cake, no questions asked.
and it is A LOT more efficient than a 20.1 is.
::waits for the IA boner to pop up::
::waits for nobody to believe these results::
and btw voltage didnt drop below 12.4 volts during testing.
bring it on haters.
Well here are the resultsclamped the IA @ .5 ohms again.
so IMO overall...
bring it on haters.
hows abouts the Orion?
TypeRBass
Walls are for wussies
TypeRBass
Tinley Park, IL
BassAddictJ
