New SQ/SQL sub options
What Sub for SAX-1200D
  • Total voters
    34
Know of anything coming up denim? Getting my car tomorrow!
The current coupon code is rare. We don't do sales often, largely because we don't jack our prices up to have the margin to run sales everyday. Drivers like these are expensive to build and machine in the USA.
why dont you contact splaudio on here and have him make you a custom sub for everything you want
that would be my choice
Dont think im down for that but thanks. Got the car yesterday completely stoked. Ill be able to get the dimensions of the box in a few hours to get the exact idea. 2010 A4 black //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif)))))))))))
That actually kinda looks like my dimensions... If it is or close, I have a single 10" ported, with about 1.25^ft net tuned to ~33hz. So hopefully your dimensions are a bit bigger than mine haha. Otherwise you might be able to fit one 12 with an aero. If you do have a bit more space than me, you could maybe do a pair of 10's with an aero.
Almost positive im going to go with the Fi Q 12 dual2. Powered by a Sundown SAX-1200D parallel with the big 3 done. What options should I get on the sub for ported?
Yea that should work for the sub amp no problem. I'd ask for the 150a fuse upgrade though.
If you're planning on running another amp for the speakers, you'll need either an additional run of 8 gauge. Or if you'd like, you can use 1/0 to a distro, then 4 gauge to the saz1200, and 8 gauge to the speaker amp.
Yea that should work for the sub amp no problem. I'd ask for the 150a fuse upgrade though.If you're planning on running another amp for the speakers, you'll need either an additional run of 8 gauge. Or if you'd like, you can use 1/0 to a distro, then 4 gauge to the saz1200, and 8 gauge to the speaker amp.
Yeah actually im just going to custom order the wires. Im going to need allot less length because everything is in the trunk. Will also only need like 3 feet of RCA so that amp kit is way overkill. Basically getting the same wire but just shorter. and ill grab the 150a fuse //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. My build log is now up in the build log forums
How do you only need 3 feet of RCA cable? Is your amp going under the dash? lol
Im disconnecting the sub wire and adding a Line out converter. The amp is 2 feet away from the wire. Ive heard from a couple people that this is the best way to keep the factory head unit and add a sub for an Audi A4 B8
helotr3vor
helotr3vor
Irvine, CA
THATpurpleKUSH
