New Setup / Wiring Questions.
I currently have these speakers, subs, and capacitors:
Subs all Rockford Power T1::
Model Size Quantity Watts Per Sub R/P
T112D2 12" 2 600/1200
Speakers all Rockford Power T1:
Model Size Quantity Watts Per Speaker R/P
T152C 5.25" 2 60/120
T1572C 5" x 7" 2 75/150
T142C 4" 2 40/80
Capacitors all Power Acoustik:
Model Size Quantity
PC1.5F 1.5F 2
I am getting new Amps and head unit:
Speaker Amp = Power Acoustik REP4-900
Sub Amp = POWER ACOUSTIK REP1-2700D
Head Unit = Power Acoustik PD-710T
So first of all I want to make sure all this will work with the items I am have?
Then I need a complete list of every size and type of wire I would need. I don't want to buy a wire kit I just want to buy all the wires separate so I can get them in all black. I also want to get the steel wire ends I would need to hook it to the amp and too the capacitors. I want to do one cap per speaker. Also any other splitters I would need. Just try to explain everything in very basic terms.
Thanks and any help is appreciated!
Ok the amp for the subs needs to be 1 ohm stable. Doubt that amp puts out even half rated but should of if stable at 1 ohm. You'll need 0 gauge power 17' a distro block to split the power for both amps also will need 10-20' of 4 gauge wire 17' remote wire 3 set of 2 channel rcas fuse and bock for under the hood 40-50' 16 gauge speaker wire 6-8 ring terminals. Also the caps. I'd try to sell. Do the big 3 instead you'll get better results
Is all this the right stuff?:
1 bundle of 0 Gauge:
THE Install BAY 20' FT Black 0 Gauge AWG Power Wire Cable Stranded Positive Feet | eBay
1 bundle of 4 Gauge:
20 FT AWG 4 Gauge Black CAR Audio Power Ground Wire Cable Super Flexible | eBay
3 sets of RCA 2 channel RCA:
6' FT 2M 2 Channel RCA Audio Cable Female TO Female Stereo Wire | eBay
1 0 to 4 gauge dis box:
http://www.ebay.com/itm/Tsunami-DB701-2-1-0-or-4-Gauge-In-to-6-4-AWG-Out-Ground-Distribution-Block-/390647163454?pt=US_Car_Audio_Video_Distribution_Blocks&hash=item5af462aa3e
1 bundle remote wire:
20 FT 18 GA AWG Gauge Black Primary Power Ground Remote Wire Cooper Cable | eBay
2 bundle of speaker wire:
Soundquest SQVLS165B 16 Gauge 25 Feet CUT From Pool Speaker Wire Black | eBay
1 bundle ring terminals:
14 16 Gauge 25 PK Uninsulated NON Insulated Ring 6 Connector Crimp Terminal | eBay
I know the box is a little over board it was one of the cheaper ones. The only thing I am confused about is the fuse and block for under the hood? Also the caps are already pre-drilled in my sub set up. There right next to my subs. Also I took the wrap off of them so know its just exposed brushed aluminum it matches my speakers a lot better. So it would be very hard to get rid of them. Also what kind of terminals would I need to hook into the amp?
Thanks!
drummer4261900
Dayton, Ohio
gckless
