New setup *upgrading*
Kastlez_
Suggest a good dual sub setup most likely going with either (2)12's, or (2)10's and if you guys it'll be better i'll just go with (1) 15 that can take the power. I also wanted to cut down on the space needed for the box seeing that my current setup is (1)15 BL that takes up the entire trunk //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
factors:
1) Trunk Setup (honda accord)
2) Running off 3000w RMS total
3) need something that's very musical because i like the way my FI BL sounds so SQL is what i'm aiming for if not just straight SPL
Suggestions appreciated i know most of you have heard or owned some killer setups
If you want to save on some space your best bet would be 1 12" ported. Find a 12 that can take all 3000 watts. Or maybe 2 10's in a smaller ported box.. not sure how much airspace your giving your 15 though so that might still be to large for you??
go IB and save uber space and watts, and have the uber lows //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
What's your electrical consist of on the Accord? I have a Civic, and can't upgrade due to having a small alt.
stock electrical i'm going to have to look into an upgraded alt but they are soo pricey //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
I'll most likely upgrade the battery under the hood along with one in the trunk.
stock electrical i'm going to have to look into an upgraded alt but they are soo pricey //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gifI'll most likely upgrade the battery under the hood along with one in the trunk.
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
How many batteries did you need to add? Yea, an alt for my Civic is $500 and better.
approx. 3.8cubes for my 15 maybe i'll just upgrade to one 15 BTL
I've only had this one setup so i'm not sure what the audible difference would be in 15BL vs 12bl vs 10bl
I mean will one play louder/lower/higher/etc. than the others?
Not sure i was thinking i should be fine with a new under the hood and one extra in the trunk for a total of (2)
Maybe yellowtops or dekag31's
Kastlez_
Kastlez_
Bay Area, CA
zack39648
