New Install Pics
pretty good i'd give it a 7/10.. but the box is built **** nice.. i give a thumbs up to whoever built that... besides the construction of wires inside the box.
The whole box was built complete (all four sides and dished). It was gonna look exactly like my other box but with the port in the middle and 2 10's obviously. Then I ended up getting the XX-Herc which is bigger then my other amps so it threw everything off. So we flipped it around and made the subs dished (instead of the amps like my old install) which worked out because otherwise the port wouldn't of worked. Then the port was made and the sub holes cut and edges all routered. Its tuned to DD specs, not their 40hz reccomendation but they have specs for 36hz too and I wanted it lower since I have another box with 2 6" aeros for comps. You won't be able to see that speaker wire inside when the port gets painted and the wire clipped to the roof.
Here is the front end too btw... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Very nicely done. If you can take it to the next level a create a false floor to hide all you wires, it would make a world of difference. It is still very nice. Still has good attention to detail. That must hit hard.
Definitely my favorite sub I have heard in terms of SQ - Output ratio. I wish I would of been able to keep it for a show piece. The glue around where the cone meets the spider let go when I accidently did a 40-0hz sweep. That is what led to this system. I sold it to someone who was good with glue and its in his car now.
how did you like the brahma?
Fixxer
Sundown Audio
Fixxer
Canada
Fixxer
