New gorrila glue = bad
PSturmer
well i would just like to say that it sucks. it says its stronger and can dry in 1-2 hours. so i glued the 2 pieces of my port together with it. i let it sit overnight and i brought it into to school to route. the bond broke.
just giving a heads up to everyone to buy the older gorilla glue not the new.
here is a pic of it
don't need it to build a box anyway. We post repeatedly that wood glue is still the BEST and is all you need for MDF boxes.
*8 pages of glue talk on the way*
pics of said wood joint? that crap swells|expands in the joint and makes them WORSE.
it was in 70 degrees. i liked gorilla only because of the set time. at school i have an unlimited supply of titebond 1 and 2. so i am using that for now on.
here is a pic of it
It is an amazing glue....i mean amazing..however, on wood, Id rather use the paste from the back of a stamp to hold it together...
Did you put enough water on each side of the wood? If you don't put enough, it won't bond well at all.
Either way, the stuff is terrible to work with and too expensive. It does hold quite well though and the MDF should have failed before the joint unless you did something wrong.
im sorry liquid nails is almost as bad as gorilla glue...
i did a stress test with some 90 degreen angle pieces
1st place went to Loctites wood glue
2nd place Titebond II
3rd place Liquid nails
4th place gorilla glue
5th place no glue
PSturmer
PSturmer
Minnesota
baseballer1100
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
