New components on the way.......amp suggestions???
bdmach1
Just ordered some Cadence CVL-6K components through Jason Paul and looking for some opinions on what amp to purchase to power these........let me here your suggestions!//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Thanks
Bob
Nobody has any suggestions????//content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif
Here are the specs on the component set....
6.5" 4 Ohm Woofer
3" High Temperature Voice Coil
RMS Power: 200
Peak Power: 300
Frequency Response: 35Hz-22KHz
Sensitivity: 95db @ 1W/1M
Mounting Depth: 2-2/3"
Butyl Rubber Surround
High Strength Mica Filled Polypropylene Cone
Diamond Cut Dampened Cast Aluminum Frame
25mm Ferro Fluid Cooled Silk Dome Neodymium Tweeter
External Crossover
14 Gauge Wire Terminals
Need to do something real soon.....give some ideas, new or used! Iwill be running these passive for right now so let me know what you guys think, Like to stay around $300.00 or under if that's possible.....
Thanks
Bob
look into the alpine MRP-F300
RMS Power (at 14.4V, 20Hz-20kHz)
Per channel into 4 ohms: 50W x 4 (1% THD)
Per channel into 2 ohms: 75W x 4
Brigded 4 ohms: 150W x 2
that should be good for your components if there 200rms
it retailes at 230 but im sure you can get it online for probly like 150
Anyplace I can purchase on line?? Awsome amplifier by the way!!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
they are not sold online. contact DD and they will either set you up with a dealer or sell direct. i got mine from a guy on here though. the S4 does retails for around $550 though. they aint cheap.
bdmach1
bdmach1
Akron,Oh
tcguy85
