New Car Need New System HELP
  • 2
Scumbag2005
Ok i use to have a 96 ford explorer and had two 15" audiobahn subs in there now i got a 2002 Ford Explorer Sports Trac the truck and there isnt alot of room so i was goin to put one 8 under the backseat anyone havea suggestion on wat kind
my thoughts now werea Kicker 04S8L7
Subwoofer Specifications
Rec. Sealed Box Dims: 0.33 - 0.75 cu.ft.
Rec. Ported Box Dims: 0.66 - 1.00 cu.ft.
Free Air Usage: not recommended
Sensitivity: 84.9 dB
Frequency Response: 28-100 Hz
Recommended RMS Power: 450W
Peak Power Handling: 900W
Impedance: dual 4 ohms subwoofer wiring options
The problem is you are going to have to find a shallow mount sub. Most of the higher watt subs are not shallow mount. You are going to have to go with a sealed box. I have the same thing under my truck seat. I bought 2 concept 10's for that truck. It ***** unless you are willing to give up the back seat for a box.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
305
A Link would be very helpful. Id be interested in taking a look at some gear
281
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
736
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
Scumbag2005
Scumbag2005
NEW YORK
Scumbag2005
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
