New build for the Jimmy with a Warden 21"
Did you resin the box?
no, it's a clear coat on the outside.
---------- Post added at 02:36 PM ---------- Previous post was at 02:35 PM ----------
weres the vids?
oops
---------- Post added at 02:36 PM ---------- Previous post was at 02:36 PM ----------
Where the fuq do u get a 3" roundover at
it's a 1.5"
---------- Post added at 02:37 PM ---------- Previous post was at 02:36 PM ----------
first test with both ports open @43hz, powered by 2 sundown 1500's:
Where did you get the 9" tubes from? I've only seen 8" then 10" sonotubes at home depot.
these were with the 8" tubes at HD. they vary in size from about 7.5" to 9". I just grabbed the biggest one.
---------- Post added at 12:11 PM ---------- Previous post was at 12:10 PM ----------
Box specs?
It was 8cubes at 29hz with one port and 39hz with both ports
Thanks for the reply, and also was it enough port area when the you had one port closed off and how did it sound? I'm wanting to do the same setup with a dp 21 and 8" Quikrete tubes.
16
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
992
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
Flastrongman
Flastrongman
Ft Myers FL
Flastrongman
