new battery or HO alternator
tweety_5150
currently i have a MTX Elite te1501d amp witch makes about 1700w rms its pushing 2 kicker l7s and im going to get a kicker 850.4 or a 650.4 amp for the mids and hi's, right now when the bass hits the lights dim like crazy should i get a HO alternator or a battery, if i have to get a battery i was thinking about going with a kinetic but not sure what size i should get, i will be doing the Big 3 withing a week. If it makes any difference i have a 2000 mustang gt conve the stock alt makes 130a.
how much cable would i need to do the big 3. Can i just connect the wire from the alt to the battery instead of alt to the fuse box then the battery?
Yes you can. It is highly recommended that you fuse this wire though. Don't forget to do your B- to chassis and alt casing to chassis.
you really dont have to put a fuse between the + on battery to the alt, but some cars have it fused, some dont. i did a straight run to it and works just find. now i got less dim than before for sure. for the big 3, get at least 12 ft, depending the distant between the bat and the alt, and make sure you get true 1/0 wire. dont get some fake ones. i bought some knukoncepts ultra fleks for at least 3.75 a foot. very but very flexible. and for the terminals, dont crimp it, solder it for a secure fit. i almost forgot, on the big 3, follow the negative cable on the battery, it will lead you to the engine block in most cases. and prefer to upgrade the battery terminal to 2 1/0 gauge terminals. sorry for writing alot, i dont want you to mess up and end up paying a shit load just for replacements.
what i did before was goto autozone and got a 2awg battery cable and it worked fine one my 200 amp alternator for the extra cable
FYI - only an idiot neglects to fuse the alt to battery wire on purpose. it's a fire hazard because the new big 3 wiring is NOT routed to factory specs. factory wiring is routed to the fuse box and yes, it is not fused at the battery. but the routing is well secured and well protected, and along the firewall. the big 3 alt wire is usually around the radiator - not the safest location. also, when you add a wire to the alt terminal, you compromise the factory wire protection.
if you're adding a wire to the battery, it must be fused as close to the battery terminal as possible. if not, and that wire grounds out, your battery will explode - imagine this happening while driving - you could kill someone.
here is my alt positive to battery installation of the big 3 in good detail:
http://forum.sounddomain.com/ubbthreads.php?ubb=showflat&Number=1804618&page=1&fpart=2
tweety_5150
tweety_5150
oakland,ca
keep_hope_alive
