new amp help
fordman86
OK 15 years ago bought a mtx 5400x 5 channel amp hooked it up to my stock head unit and power a pair of mtx 8's. So been a while since I did any of this it finally burned up so I bought a Memphis 5 channel hooked it up just like the mtx but now have no power to the subs. Any ideas did the mtx have different settings.
Everything was working fine was playing radio on my way to work and all of a sudden got a high pitch squeal and then the amp started smoking so pulled over and disconnected the negative wire didn't want to catch truck on fire.
Should I check each sub or can I just check the wires going to the enclosure. It's one of those plastic molded ones mtx made back in the day for the f150's. What should the resistance be.
OK finally pulled enclosure one sub 6.5 and the other .2 with a sticky cone or something. When you push down on the cone it stays down until you push it back up. Could I hook up the one and see if I get sound.
fordman86
fordman86
iowa
I'mPoor:(
