Is there a way to connect bare wires to a RCA video plug?
xray328
Hey guys, noob here. I need to run three bare video wires (+, -, shield) to a standard RCA video plug. I see adapters to do this for standard audio wires, but is there any way to do it for a video cable?
I'm installing a factory backup camera that has a regular oem harness to an aftermarket setup but the aftermarket unit uses an RCA plug.
Thanks in advance.
Thanks in advance.
The shield and the negative should be the same for RCA.
Depends on the type of cable used.
Also, depends on the type of cable used. twisted/shielded wire you choose one to be negative, one to be positive and cut off the shield.
I believe he meant the connector itself, not the cable. There's no reason to cut the shield off, either. For an unbalanced input of any kind, using the shield as a ground is much more effective than using "twisted pair"
xray328
xray328
Chicago, IL
SounDrive
