New Alt or Add Battery?
Which would you do?
  • Buy the Kinetik HC2400
    Votes: 10 43.5%
  • Upgrade the alt (160 amp)
    Votes: 13 56.5%
  • Total voters
    23
well I agree with everything except the isolator part. I have a stock battery and a fairly new yellow top with no isolator...never had em drained. In fact I've even left my dome light on accidentally and that STILL didn't drain them //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yes i've heard people say either way but i've definitly seen a couple battery systems die that way too, so you are taking a risk,
in your case your yellow top might probably only be discharging to the point so that its equal with the stock batt....
might be interesting to test and compare them after sitting for awhile...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
if it is doing that, then you've wasted your money on the expensive yellowtop and you might as well have bought a battery identical to your stock one
car has been sitting since friday afternoon, both batteries just tested at over 12.5 volts.
Thanks for your concern though //content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif
i had a stock alt and a yellowtop and i ran 2 bxi2006ds and my voltage enever got down as far as yours.
but i'd keep the same brand of battery's....on the other hand i personally bought a hc2400 from xplorer22's and the transaction went without any problems so that is a choice
Qbenjamin
Qbenjamin
Braavos
audiolife
