New alt is in, troubleshooting.
Buck
little alien on campus
Ok. New alt is in. 300 amp with external voltage regulator. At idle, it's doing stuff that I don't think it should be. The voltage is jumping around .3 volts and it's like there is a load constantly being taken on and off. You can hear it in the engine. Also, at idle, my headlights and dome lights dim and get brighter, seemingly with the engine. My check charging system light came on, but I expected that.
There are two wires on the factory harness- an orange with light blue and a green with red. I'm not sure what to do with these. Thoughts?
youre not going to have a "turn on" rpm...the alternator produces power when turned. Its an armature getting turned and itll provide power being turned very slow, albeit not much.
It has to be something to do with your car...does your car regulate voltage through the computer, or was the alternator internally regulated?
The stock alternator used to regulate voltage through the ECM, but that's why I got a external voltage regulator. I can control the voltage now, I just have to figure these things out.
Buck
Buck
Inside of a pyramid
Buck
Mike Mccabe
