SOLD *new 2 Channel Amp*
  • 3
barto
USX amp model # 4065 AWSOME AMP
Amplifier Type: Multi-Channel
RMS Power: 65W x 4 @ 12.9V
Bridged RMS Power: 160W x 2 @ 12.9V
THD at Rated RMS Power:
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Frequency Response: 10-30,000 Hz
Channel Separation: 80 dB
Signal to Noise Ratio: 100 dB
thats the specs ummmm
it is new
never used never even taken out of plastic!!!
make an offer
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
145
6
374
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
755
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
835
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
barto
barto
Pittsburgh, PA
barto
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
