Never thought it would happen to me...
water doesnt realyl filter anything. the point of a water bong is to cool the smoke down. weed has almost 500 different carcinogens in it, cigs have less than half that. and ur pipe gets you higher because there is less airspace so you get more concentrated smoke by volume.
My bong gets me higher than any pipe does. Using the same amount of weed, If I load it in the bong it will do a lot more than if I were to put it in the pipe.
Oh, really? Do you know the chemical structures of all of those carcinogens? You know for a fact that not a single one can combine with an H2O molecule?
By the way, pipes do not get you higher. You should try to use some real science.
its all in your head. the difference is nominal. take it from someone who isnt fried all the time.
The difference has to do with chemical reactions, of which you obviously know nothing about. Take it from someone who can comprehend simple chemical properties(middle school science, if I remember correctly).
ok smart guy. i was merely explaining why this other idiot might think he gets higher from a pipe. there is in fact no difference if the same amount is smoked as i just stated in another post. youre a fcking moron, i just said that water doesnt filter anything and you argue with me by saying water doesnt filter anything. thanks for enforcing my point in the form of telling me im wrong. dont post again youre ****** retarded
obviously smoking weed has certian health risks you are inhailing smoke into your lungs its not rocket science! ville audio i would like to know where you get ur facts from not that i am saying your wrong but i have a hard time believing weed is more harmful to your body then ciggerettes.
it technically isnt. the fewer carcinogens in cigs are more harmful than all of the carcinogens in marijuana. im just baffled by this master deadeye character, his point is the same as mine yet he continuously shoots down everything i say.
# Pipe - You've probably seen people smoke pipes of tobacco, but these pipes are also used to smoke marijuana. About 40 percent to 50 percent of the THC is transferred into the body when using a pipe.
# Bong - These are water pipes that typically have a long tube rising out of a bowl-shaped base. Water pipes trap the smoke until it's inhaled, raising the amount of THC taken in.
Taken from HowStuffWorks "Marijuana Usage" so bongs get u higher, case closed
Wow, where do I start? Let's start by going back to the post you quoted about pipes and how much THC you ingest compared to waterpipes(JoshC's post). In that post, he said that he does NOT think it makes him higher, but that it changes the flavor. Your response to that was, "you get higher with a pipe because it's smaller". In your next post, you said that the difference is nominal. In the post I'm quoting now, you said there is no difference. You've changed your opinion three times now, sir.
Next, I'll take you to the waterpipes and carcinogens argument. In the post you quoted in the post I'm quoting now(follow along if you can), I was asking you questions. You can't answer those questions because you do not know the truth. I was actually implying that many of those carcinogens, or at least a few of them, are deteriorated from the water. Do you know what a radionuclide is? Do you know what it does? How it's created?
I rest my case.
IonRL205
DJ h4z4rdes
IonRL205
Abilene, Texas
AlterEgo99
