Never installed b4 a few ?'sss
  • Thread starter air_odie
  • Replies 0
  • Views 429
air_odie
I have never installed a audio system b4 like this at least...
items I know I need.
HU=Eclipse CD8455
dashkit
harness
COMP side
comps=BApro60's
amp=Xenon 200.4
Rca's=Kar4-6m
SUB side
2 Incrim Audio LI 10's w/ thinderform box(MTX)
amp=Xenon 1200.1
Rca's=Kar2-6m
Other Stuff
Pwr kit=KOL-AKO 1/0Gauge 18' pwr kit
Fuse kit for alt to batt in big 3
pos and neg aftermarket batt terms
100' of 12 ga speaker wire.
so far from what I understand this is what I must do
[battery-]--[chassis]-------[ground/distro-]===[amps-]--spkr-wire--[subs, spkrs]
[battery+]--[fuse]---power-cable--[distro+]===[amps+]--spkr-wire--[subs, spkrs]
`[headunit]--------------rcas-and-remote-leads--------^
What else will I need to install this? Vehicle is a 2000 Dodge Dakota and plan on installing the amps in the club cab portion between interior and exterior walls. plenty of air flows through so seems good are and outta site so less chance of theft. plan on installing amps into wood board that has been liq adhered to the trucks inside exterior wall. Plan on running power side down drivers and signal/speaker down passenger.
I have two AMPs so how do I wire the signal feed for them? will it need to be relayed?
Do I need a power distribution block for the + side of the amp at the rear of the club cab?
Am I missing anything else?
should I bi-amp the comps?
Thanks
ODIE
air_odie
air_odie
FLA USA
air_odie
