neon lights
im pretty sure that its not to hard. you have to buy a unit that makes them play toi the music. i have seen them in crutchfield for like 30 bucks. hey come with instrucions
i hope this helps
Ok everyone thinks you need some unit to make the lights flash, you dont at all, ill tell you the secret to save you that 60$. What u do is hook up the positive wire of the neon tube to the positive terminal of the sub box. Then connect the negitive wire to the negitive terminal of the box. And then you will have the light flashing w/the bass(sweet huh?)
Good luck.
If you have any other questions just ask.....
NO NO NO!!! dont do that!
If you do that you risk blowing your amp!
My buddy had the same idea and he fried his jl 250/1
Just think about the current being supplied to that little neon tube? Not to mention screwing up the impedance of the sub.
I know it looks cool but trust me it isnt worth it.
Came across these. Rechargable, so you don't need to wire anything in and have a OEM look. I don't know if they're reliable or anything, I just...
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
CheapPyramidStuff
CheapPyramidStuff
Kamloops BC Canada
schrunk
    May 31, 2024
    May 24, 2024
