U
Unregistered
Guest
is it possible to wire a neon light through the amp so i dont have to use my cigarette lighter? or if its not through the amp please let me know thanks
Can you back that up with any info? I don't see why it would matter, you run the h/u with it, the amp, and I've used it for cooling fans, so I don't see how it's gonna affect your h/u. It's not actually coming from your h/u, because it in fact uses the remote. Depending on whether you want the neons going on with the music, you could also run it with your light switch, because I doubt you would want them running in the daytime, but you could always turn them off. It's up to you and how much work you want to do. The remote would be the easiest.i'm sure that running the neons off of the remote turn on lead from your h/u cant be good for your h/u
Actually, its no good. The remote lead wire runs through the H/U on a tiny fuse. If you put too much load on it that lil fuse is gone, and you have to pull H/U out to fix. Just run wire from batt. or cap through a switch, and connect other to ground.Originally posted by Phatillusion
