neeed box design asap =)
kyleorsini
need a design for 2 12" mach 5 audio spl drivers, subs up, port up tuned to 36
double baffle, and some 45s in the corners, i will be adding a couple dowels in for support but dont really need to acount for those,
would like about 5-6 cubes after port displacement
aswell max dimensions are :
w 38
d 25
h 25
would like to start building tomorow if possible thanks guyss:D
5-6cu.ft. is too big imo, especially with that little amount of space. try 4cu.ft instead with a monster port.
with those dimensions it comes out to 11.67 cubes just for a box, cant tell me the port is going to be 5-6 cubes in displacement:confused:
marco ygpm
Please explain this reasoning. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well, depending on the power he may (or may not have available) the net volume could change. 5-6 cubes is 2.5-3 cubes per sub which isn't all that crazy for some 12's. Assuming he might be low on power (since those SPL's can take an ***-load), a bigger box will be a little more efficient on the lower power he might have available.
If marco has you taken care then nevermind. But if you're still in need of a cutsheet, hit me up.
its probably over braced ( 3 sdies are doubled. if thats too much wood i can tell you how to make it work without extra 2 walls)
port walls:
13.25x16.75 (one side cut at 45* angle)
3.1x16.75(also 1 side cut at 45*) (will show up as 4.6 in the sketches... i forgot about the baffle adding to the length of port ftl haha
6.625x16.75 (45 cut on both sides)
45's:
1 8.5x16.75 inside port corner.
2 4x16.75 opposite port. on top and bottom.
Top and bottom:
Top (2x) 36x19.75 ( sub cutout and port through both. port .75 from side and 1.5 from front and back 16.75x5.25, subs centered front to back and 7 inches from side/port opening. 11" cutout) can also flush mount if you'd like. willing to help you work that out.
bottom 36x19.75
left and right:
both 16.75x21.75
front and back:
both: inside(smaller) 34.5x21.75
outside(longer) 36x21.75
that's a huge diagram..//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
you got pm marc..//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yeah i forgot to resize them... pmed back.. with a list of some bandpass designers... im not comfortable with them and would rather not supply you a bad design.
kyleorsini
kyleorsini
winnipeg,mb
marcotheclepto
