Needing ported box design
Hey guys I need a ported box design for a nvx vcw 12 it's going in a 1996 mustang gt without the Mach system. Any help would be appreciated. I do believe I have around 14 inches of height available. But the problem with the box is getting it through the opening in trunk/back seat. Would it be easier if built in the trunk?
I've done a few enclosures for these older Mustangs. The only way you're going to fit a 12 in is through the back seat with a sub up box with roughly 10" box height.
Sent from my SCH-I605 using Tapatalk
I haven't had very good luck doing sub firing up in sn95's. I built a rear firing box for an Ab HD 12" to fit my buddy's 96 gt. Was a tight fit but it went in through the trunk, like taking the trunk weatherstripping off to get it in kind of tight.
OP, I may still have the design but if not I'll see if I can swing by my buddy's so I can measure it.
Sent from my SM-G920T using Tapatalk
Definitely not ideal in a trunk build but when they already have the sub you gotta make do.
Chad21000
Chad21000
Savannah GA
The_Dealer
