Need To know whats wrong (wireing)
stevenslrp
It's simple and dumb but I don't know whats wrong. I have a pioneer cd player that I'am installing. It has no wire diagram. After I connected all the wires I get no power??? I just get a green light that I can see coming from inside the cd player. I
hooked the right/rear negative up together, and the right/rear positives together.
front/right negatives together, and the front/right positives. Then I hooked up ignition to ignition, and power to power, then ground to ground. Power ant- to power ant. But when I turn the ignition switch... Nothing??? But a green light coming from the inside when I push the eject button.
I don't know whats the problem, The cd player worked fine in my cousins car. I also tried a different cd player. An Alpine CDA-7873. Both I got that same green light. It must be something I'm doing wrong.
Is there an alternate way.
ummm....did you push the power button?? Dumb question I know...but I'm speaking from experience //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
The unit will completely black when you first install it.
stevenslrp
stevenslrp
Muskegon, MI
SSS 18734
Mike Mccabe
