Need to find an Oscilloscope in West TX
bustaplz
Pissing off the world.
Just seeing if anyone on these forums owns a scope in the West TX area. I'm about to install a new amp and want to try to get my install as close to perfect as I can this time so I'd like to use a scope to set my gains. If anyone has any suggestions for a cheap oscilloscope(under $300) that may be an option, also. I don't know much about them, so I'm having trouble shopping for one as I don't know what to look for in a scope that's suitable for car audio. Also, can I get an accurate look at how many watts an amp is outputting by using a clamp-meter and a VOM or DMM? I assume I could get a measurement of the current through the speaker wire and multiply that by the voltage?
Thanks in advance for any help.
lol, no. you just connect the wires, turn on the power and hit "auto"
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
mmmmm auto...
the SE has a different display. you might check velleman's site to see what they say about the knock offs.
i was saying I like the 'auto' button.//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif should've put *end Homer Simpson voice *
o, got yah. x2, the auto button rocks
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
116
185
bustaplz
bustaplz
Midland, TX
bustaplz
audiobaun
    May 19, 2024
    May 19, 2024
