Need suggestions for a 1500rms amp
It's worth it when that AP clips nasty as hell and starts burning up subs and killing electrical. At least to me the extra cost is justified.
smh its 1300 clean no clip, keep reaching tho......Also if 1300 is killing your electrical, the sundown, crescendo, etc will decimate it easily
But why spend the extra for power he doesn't need? Those Daytons you don't want to push much more than rated to. He only wants 12-1300 watts. So this is basically the perfect example of who should buy AP. He shouldn't be near clipping point.
If he's not on a budget and doesn't care about spending the extra money, then yes of course get the better amp.
I take it you two have never dug into these amps? The noise they make, the 50% efficency numbers.
Have you personally dug into these amps?
Have dyno specs? Have any video of test? Do you personally have any numbers or paperwork showing proof of what you are trying to convince others of??
Sent from my Z970 using Tapatalk
Every broke basshead in Va used them. Also you can find great test on the tube. I'm not doing the work for you, if you want to see more look for yourself, they are not hard to find.
Ok, so you ignored my question.
Have you tested or dug into the amp(s) in question?
You seem to good at commenting on every topic with all your "knowledge", but you cant seem to prove anything.
All you know or seen are from your friends and past "tests". Do you have anything else to say?
Look for yourself. I'm not your babysitter. If you want to buy one go for it. Good luck.
Joel787
Joel787
Washington
mylows10
