Poor man's Oscope! Setting Gains on Questionable Sub Amps
Jeffdachef
Gunz That Turn on Nunz
Got around to trying this method today, been wanting to try out this method awhile back but forgot about it till today. It worked out pretty well, from my tests, hit up a shop to compare it with an SMD Distortion Detector and it was spot on with the DD-1
-Buy a piezo tweeter, don't worry, it doesn't matter which one. Preferably one that can play reasonably low frequencies.
-From the + terminal on the amp, run a wire to the + terminal of the tweeter.
-From the - terminal on the amp, run a wire to the - terminal of the tweeter.
-Resistance of the tweeter is like 100 ohms so you arent gonna blow the piezo tweeter.
-Head unit sub level up, bass boost, loudness and bass EQ off, keep them off on amplifiers too. Volume at 75-80%(or higher if your preout voltage *****). Play the proper test tone. Then up the gain till you hear it beep pretty loudly and back it off.
-This does not work with 2 channel and 4 channels as well as lower frequencies, works best around the sub bass and midbass frequencies.
edit: This plays on clipped sine waves but dirty amps like shark and audiopipe will have distortion before the wave is even clipped so take care not to go too crazy with those amps.
sub level up on the HU up?
Thanks! Just ordered it on Amazon //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you can cancel the order because they have these at your local radio shack, got mine for 3.50
@bgowdy thats in general, there are exceptions though some alpine head units go all the way to +15 and some people claim its not clean or the signal is too strong even when the gain is at 0. LOC and line drivers will require different settings also.
taylor fade told me this exact method as well - if he also trusts the theory behind why it works then it might not be a bad idea to try out.
ive been wanting to test this myself
but
ive been working out ground noise / alternator whine issues in my system first
and ive been a bit nervus to try out my dc 7.5k hooked to a pizzio tweet lol
luckly today i managed to nail down my ground noise issue to a blown or messed up pair of channels on a ppi900.4 amp i have installed - when i un hooked the rca to those pair the noise drasticly reduced - but when i unhooked the speaker pair left and right - there is now zero ground noise or alternator whine with the track on pause and headunit volume at 50 its dead silent now... thank god
i was going crazy trying to get it figured out
taylor fade told me this exact method as well - if he also trusts the theory behind why it works then it might not be a bad idea to try out.ive been wanting to test this myself
but
bad ground on rca inside amp ??
i hate crap like that.. meaning noise in system....
i wish this could work for all amps.. 2ch and 4ch . i have one of these tweeters, may have to try this. thanks..
but
The same model as the one jeff linked to?
Jeffdachef
Jeffdachef
South Coast Metro, CA
Jeffdachef
