Need sub/s for Boat
Kold_Killa
Have 600 watts at 1 ohm... I'm actually thinking 2 10s/12s.. maybe cvr? These will be under a seat, out of the way, but I'm still wondering if there are some specifics I should look for in a sub that will spend its time in an "open" condition like a boat.
Probably not paper cone huh? Also thinking it is probably necessary to do a sealed box and seal it up tight in order to avoid humidity and moisture problems? Maybe coat the box in a resin and then a marine carpet?
I've never done a boat install before so I'm needing a little direction.
I think basically:
2 300 watt woofers (dual 4) or 1 600 watt woofer (dual 2)
Rubber surround? Non paper cone?
Work decently well sealed
Looking for some nice spl, and tolerable SQ...
Thanks
Btw, it's a Cobalt Ski w/ a 350 (no clue on alt size.. I may be upping it)
idk about the subs but id coat the box in truck bed liner to keep the box dry
I don't know if they make a small enough can of roll on... If I had to buy a "tub" that cost 100 bucks it wouldn't be worth it, but I like the idea if I could get out for like 20 bucks or something... Ya'll think 2 12 cvrs could get the job done on 300watts a piece?
Short answer, yes, will get the job done. If a car is not a perfect acoustic stage, a boat is acoustic hell. Don't go for SQ subs because it will be hard to tell the difference. The CVRs sound good.
kicker makes a marine line of products now I believe for amps.
Box needs to be waterproofed by sealing it with any number of products.
sub CONES, if they are paper, could use a coat of flexible poly.
the box probably ought to be sealed to keep out moisture, trash, vermin, etc.
BATTERY ISOLATOR would be a good addition to this setup
got pics of said boat?
no pics... it's at the lake in the shop... It's a 93 that looks like an 03... it's a beaut! There will def be pics once install is done... Month or so......?
Can CVRs get loud sealed? What should I use to "coat" the box? Um... thats all.
Kold_Killa
Kold_Killa
Little Rock, AR
lvfive.o
vegang
vegang
