helotaxi
Kilroy was Here
When fully charged, a cap is no strain and a battery is a very small (1A) strain. That isn't the problem. The problem is when hey are doing their job and discharging. They then must be recharged. Because of the low resistance of the cap, it becomes a drain on the alt as soon as the demand from the amps goes down into the range of what the alt can provide. A battery is the same way and multiple batteries present an even larger load.
The caps in the amp are more to filter out the ripple from the car's electrical system and to filter out the ripple from the switching power supply than to provide surge current.
I won't say that extra batteries and/or caps don't have their use in car audio. I will say that 99% of the people out there use them in the wrong situation. I see one purpose for a cap, and that is in a system where the alt is providing more than sufficient current to power the system, but needs a buffer to provide instant current for transients to allow the voltage regulator in the alt a chance to catch up to the current demand. The use I see for extra batteries is playing the system for short time with the car off. A big battery with a high skin voltage can serve the same purpose as a cap does above.
The point is, if the alt, the only SOURCE of current in the system, can't keep up with the current demand of the system and the storage devices are tapped deeply and regularly, adding more storage isn't a solution, it might temporarily mask the effect of the problem but it certainly won't fix it.
