Need Specs for SW9122
Sorry, you'll have to ask Eclipse for the T/S on the Ti, but the The TC-3000 is your closest match
Here is the URL
http://www.tcsounds.com/tc3000.htm
ths site is brand new, and the DNS may have not resolved, if so, use this link
http://www.tcsounds.com.unixweb-7.nethere.net/tc3000.htm
This is for QVC only.
Code:
Qts 0.303
Qes 0.325
Qms 4.38
Fs 24hz
Res 5.86Ω
Ls 8.85mH
Lp 19.25mH
Rp 25.95Ω
Dia 254mm
Vas 50.40l
mms 301g
cms 140m/N
bl 29T*m
Spl 86dB
Can anyone give me the specs for SW9122 Eclipse Titanium 12"
For Example: The papers that come in the box (Pic or Info)
OR
Qts
Vas
Fs
Re
Le
Xmax
Z
Qms
Qes
Pe
BL
dia
Sd
Here ya go.....and good luck with getting your response from Eclipse!
Fs 27.676Hz
Vas 32.4L
Sd 430cm^2
Qts .328
Qes .351
Qms 5.00
Znom 8 (series)
Revc 5.9 (series)
Xmax 23.15mm
Bl 28.00Tm
Pe 1000Wrms
BoboP4C800
BoboP4C800
Navarre, FL
jimmyjames1700
