Need sound system help
specialagentPK
Ok I have a Fusion FCD-255 deck and so far just a set of Fusion 6.5's in the front with tweeters in the door not installed yet plus ordering some Infinity Kappas 4x6 for the back in a 01 GMC Sierra Ext Cab
What I would like to do is add tweeters in the D pillars in the back and a set of 2 10" subs under the rear seat.
So a few questions
1. What wattage sub do I need for the speakers. I assume I need a 4 Channel amp to run each speaker seperatley and what company should I go with please name a few.
2. For the tweeters, if I order a set seperatly do they come with that little box to run them(I don't know what this is called Crossover Box??)??
3. What is a good sub company as well and what wattage should the subs be rated at??
4. How many watts on an amp do I need to run the sub and again I assume I need a 2 channel amp??
5. Should I ditch the 4 ohm impedience front speakers and get some 2 ohm ones or should I find 4 ohm 4x6 rears or does it matter if the front and rear impedience are different.
If there is anything else I need please let me know or if I am setting it up wrong let me know what I need.
Also as for ratings on the truck it is a 145 amp alternator and dual battery setup
I have a limit of about 1500 and this system will mostly play rock music.
Ok now that I have decided on speakers and whatnot.
Here are my front components.
Morel Dotech MK2 6.5" Components
http://morelhifi.com/products/mob_2way_dotech.html
I am going to use this amp for them:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2959
My Subs Are 2 of these:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2926
And I will use this amp for them:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2963
I am unsure if the amp for the subs is the correct amp to be using but it seems right. I will hook them both up to the same amp and that should cut the the rms power of the amp in half and if I am carefull with the gains I should be fine. If there are any faults with this please let me know as I need to order them today.
Also I am looking for an SQL system
specialagentPK
specialagentPK
Whitehorse Yukon
specialagentPK
