Need someone to design a box for me
Andrew2006
I have a 18" Audio Que HDC3 being pushed by a SAZ 1500D and was needin a really good box designed my max measurements are 38wide X 22deep X 28 High i was wanting sub faced back and port under sub tuned to about 34 to 38 somewhere around in there just hit me up thanks alot
Andrew.
Do you need one built also?
If you want you can give me a call and we can talk about exactly you want to do with your sub/box, I can get you a plan or build. either way I be happy to help
ok this is what i am needing i want the sub and port fired towards the back but i also want the port under the sub.... but this is what i need the box to be...The HDC318 likes 5.5-6 cubes net tuned to 38 hz. Make your port opening area 16 sq" per net cubic foot of box volume. For example a 6 cube net box requires 96 sq" of port opening area 19" long for 38 hz tuning. The sub displaces .4 cubic foot and the above port displaces a hair over 1 cube so your GROSS INTERNAL box volume would be 7.4 cubic before sup and port displacements.
does this look right i got this from the RE Calculator
does this sound right
Box Width 36
Box Height 28
Box Depth 21
Port Width 4.5
Port Length Total 33.25
Square Port Area 155.25
Box Volume (ft3) 7.319
Tuned Frequency 36.2
Andrew2006
Andrew2006
La Follette TN
Mike465
