need some where to run my amp wires from hood
I have plans to install my own sound system i have had it to long and i come to the decision to hook it up my self.
i would rather not drill a hole but if i have to i will but where at under the hood can put the wires through to get to the inside of the car
I have a 2003 crown vic lx
my systems is as follow
alpine head unit
3 12 inch fu audio subs
soundqubed 2200 amp
you will have to look on the firewall and look for a bundle of wire. and see if your amp wire will go into that grommet.
if not then you will have to drill a hole.
but make sure you deburr the hole and put a grommet so the wire does not get chaft and ground out.
fuse that wire at the battery .
ygbodybuilder10
ygbodybuilder10
United States
big scott
