Need some suggestions please
Any 1k rms would do just fine at 1 ohm. I would look into the memphis mcd16-1000. take a look in the amplifier classifieds sections and look for something within the 1000-1300rms range at 1 ohm.
thanks for your advice. the guys I talked to first said that a 2000 watt or a 1500 watt amp would be ok too. so what I need to get is a 2000 watt monoblock amp correct? see i was under the impression that a mono amp just ran one speaker, but i've seen one mono block running two subs. I guess that depends on wiring them together? and the different ways you wire them up decides ohms right? since my speakers are dual 2 ohm. so if i get a 2000 watt at 2 ohms monoblock amp how would I wire the subs to the amp? thanks
Lurk around this site and search for anything you might not know, you will lean a lot in a weeks time.
bumping97vic
bumping97vic
Locust Grove, OK
TreyE
