Need some speakers
Yep.
Also, I hope you noticed those are component speakers, meaning you'll have to make some holes in your door for the tweeters. It's easy enough to do, just make a 2" hole (approx.) in each door panel, and pop in the tweeter.
As for the crossovers, many people like to put them up front, close to the speakers. Like inside the door, or under the front seats. Personally, I just put them in the back, next to the amps, and run two sets of wires to the speakers. It's up to you.
-- Kevin
with the distrubution block, does it have to be a certain distance from the battery on the wire? Or can it be like close to the amps so i only have to run 2 shorter wires to the amps from that
Yes, get it close to the amps so you can save some wires. Have a long run of 0 or 4 gauge wire from the battery into the block. Get the block close to the amps, then run whatever wire is necessary from there.
So im going to go with:
5 1/4 RSD's
CA 600 (only because its cheaper and give out same power)
some type of distribution block
power wires for that distribution block
Do i need anything else?
There are already speakers on the top of the doors under the windows... are these not tweeters?
Most likely they are, but we can't say for sure without seeing it.
So im going to go with: 5 1/4 RSD's
RCA wires, speaker wire, remote turn-on wire.
-- Kevin
xNaStYx
yo
xNaStYx
lolz
xNaStYx
