Need Some Help With Wiring My Subs
Alright Guys I Have A Kicker Zx850.2 And Also Have 2 S10l7 Which Are 2 Ohm And I Am Wondering What Will Be The Best Way To Wire Them To Get The Most Out Of My Amp. The Amp Is Rated 225x2 @ 4 Ohm Or 425x2 @ 2 Ohm Or 850.1 @ 4 Ohm Brigde. I Would Appreciate Any Help And Of Course I Would Love To Be Able To Get The Most Watts To These Subs, But Of Course I Want The Amp To Operate Correctly. If I Have To Add More Subs To Get The Correct Configuration That Is Fine Just Let Me Know. If You Come Up With Any Idea's Let Me Know How Many Watts I Will Be Pushing With The Configuration. Thanks In Advance
to get the most out of that amp you need dual 4 ohm subs so you can run it 4 ohm bridged. you have dual 2 ohm subs, so the most you can do is wire them in series to 4 ohms each and run your amp at 4 ohm stereo. adding 2 more subs would just be WAY underpowering them. running that amp at 4 ohm stereo you are only sending 225wrms to each L7....not enough to make them shine....you shouldve gotten dual 4 ohm subs...
nope on the first question, unless you get 2 dual 4 ohm subs.... about the 12 unless you get a dual 2ohm......you cant bridge the amp because its not 2 ohm stable in bridged mode...and you wont get any power out of it running a dual 4 ohm in series...ie:8 ohms.
So I would need to get dual 2 ohm. What kicker amp would be good to run the 2 L7 10's
THE CUTTING EDG
THE CUTTING EDG
Cincinnati OHIO
THE CUTTING EDG
