Need some help with pioneer head unit
  • Thread starter Unregistered
  • Live activity
  • Replies 2
  • Views 2K
U
Unregistered
Guest
I currently have a Pioneer DEH-835r which has 40x4 watts head unit on my system. My little cousin
dropped my face plate and cracked it, also the thing has been acting funny. Anyways I found a
really good deal on a Pioneer DEX-P78 to replace it and purchased that (still waiting for it's
arrival) After researching the head unit a little more, I see that the wattage per channel isn't
listed on the DEX-P78, instead it says Q-sound 4 volt preamps. I have a 200 w kenwood amp powering
my speakers and a 400w amp powering my 12" kenwood woofer. I was just curious how much of a sound
drop I can expect since I guess the head unit doesn't have a chip in it...or am I wrong? Can
someone shed some light...I'm not the brightest car audio person :)
Thanx
More than likely it has no internal amp by the way that you are describing it. If this is the case, don't worry to much. The thing with "dead heads"(head units with no amp only preouts) is that they are geared more towards sound quality, so with the right amps, you should be able to drastically improve your sound instead of it being worst.
with a deck that has only pre amp outs on it which the one you dexcribe does I think, you turn your attention from deck power to pre-amp voltage, 4 volts is not too bad and is pretty much the average right now. The higher preamp voltage the stronger your signal to the amp is. This does a couple things for you, one it lessens the chance for noise to "jump" on your rca lines and become a factor. It also allows your amp to take a little break, by letting you get the same output with your gains lower, than they were on your old deck..........I think you will be happy with the new deck.
Guest
gregj9
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
