Need some Amp setting advice
deadmanrob
Ok so my sub blew a few days ago and all I had in storage was a Jensen XS1212 so I threw that in a sealed box. I am still using my Kenwood Kac-7201 for an amp. If you had this as a setup how would you set the amp for best results? Also I would assume you would bridge this.
That sub is rated at 175 watts. That amp will burn those coils out. Your amp put out 500W @4 ohms bridged. I would just wire it to the Right or Left channel... and this is assuming that your sub is a single 4 ohm sub. this is what your amp is rated at
4 ohms: 170 watts x 2 chan.
2 ohms: 250 watts x 2 chan.
Bridged, 4 ohms: 500 watts x 1 chan.
deadmanrob
deadmanrob
Freeport, ME
sciontistbb
vegang
vegang
