Need some advice
anytime u planning on putting two amps on one wire use 1/0 awg just to be on the safe side.....
it also depends on how much current will be flowing from the two amps together.....
Are you sure about that? So 2 25 x 2 amps I need 1/0 wire?
Wire is so cheap, might as well get the bigger wire and run it once and be done with it just in case.
Juan
anytime u planning on putting two amps on one wire use 1/0 awg just to be on the safe side.....it also depends on how much current will be flowing from the two amps together.....
jl500.1
jl500.1
bridgeport, ohio
OldOneEye
