need some advice on 3 8" box
zOo
8
nj
im thinking of putting 3 8s into my sc3. but im stuck on whether i should use a common or sep. chamber. and whether i should go ported or sealed. i only wannna use at most 4 inches of trunk from gas tank back(hoping someone knows a lil about the SCs). that really doesnt give me much rooom so i guess sealed it is. so will a common chamber sealed enclosure be ok??
Advantages of separate chambers are bracing for the box and if one sub goes out you can disconnect it and still listen to the other two. The only real advantage to a single chamber is you might be able to save a few inches on the box size.
zOo
zOo
nj
Bake
