Need recommendations for 2 8" Subs
Rodge
If everything goes right for me financially, I should be purchasing a 06 Toyota Tundra, Extended Cab sometime before spring. I found a custom Q-Logic box that will fit perfectly under the rear passenger side seat. Here are the box's specs:
TYPE 1 DUAL 8" DUAL SUB ENCLOSURE
• Woofer mounts to MDF baffle
• Subs share one chamber- .7 cu. ft. sealed volume
• Spring loaded terminal cup with 5-way binding posts
• ABS plastic enclosure is lightweight and strong
• Includes woofer mounting screws, poly fill, speaker wire
• 4 5/8" mounting depth
I need speaker recommendations. I'm looking for more SQ then SPL, but loud would be nice as well. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Oh yeah, I'm not very familiar with the short names you guys throw around for Subs...so make and model would be great.//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Thanks.
Unfortunately mounting depth is definitely an issue. Here's a picture of that box under the seat. Not much room to spare at all.
Anyone have links to a site that sells RE8s? Also what kind of power handling do they have? What would be a good amp to power them actually?
Thanks again.
RE8 have an rms of 175, their sealed volume is .2 i think and .5 for ported. I have 4 of them in a 2 cuft box and they took 1000rms like champs untill the amp blew //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
Rodge
Rodge
Mohnton, PA
Rodge
