need quick answer please..
raven15
I saw my bass wasnt working and i check and the fuse was blown.. so i put a new one in.. turned on the cd player and still no bass.. checked the amp and the red light was on.. and checked fuse and it was blown already.. what could be wrong?
sounds to me like theres a short somewhere- maybe one of your speaker wires is grounding out, or your power wire is touching ground or something. That or the amp is messed up. Check your connections.
Alright i went and bought another fuse.. put it in and now amp doesnt go to red or green.. just stays off... is it ****ed up or something possible hooked up wrong?
Well.... Check to see if any other fuses are blown... At the battery or in the amp.... If they are replace them... If it still doesn't work then disconnect the amp if it doesn't blow put it back in the amp if it does then it's the amp....
I think that made sense....
raven15
raven15
michigan
raven15
