Need opinions on rockford woofers please!
tony1977
I have a t1500 thats birthsheet is 1883 rms watts. Im going to run 4 12s off of it and was wondering if the punch p2s 400rms could hold up to being over powered by 71watts per sub? I origually was going to go with p3s but there the only one in the punch and power line that have a aluminum cone. Just dont seem like they would have very good sound quality. I would be open to suggestions on other subs also that are close to the price and power handling of the rockfords. I can get p2s for $90 a piece and p3s for $124.
get 4 of these pre sale subs and this will ***** slaps those rockford subs, i used to run T1 and they are not all impressive just expensive, dont make the mistake i did and lost money on the T1 subs
presale on Sub 12" 600watt $99
C2 Audio Threatcon-2
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
---------- Post added at 10:11 PM ---------- Previous post was at 10:11 PM ----------
4 of those c2 audio and you can even get another t1500 and both amps will run 4 of these subs all day
tony1977
tony1977
Webb City Mo
naughtyca
