Need Opinion
grkstang
nyc
I currently have 2 amps and MRV-F407 and MRV-T757 both Class a/b
I have the CD8443 Eclipse HU.
I am running an active setup in the system F407 is high passed and runs the 1" highs. 65wrms x 4 ( actuall setup 65wrms x 2 and 160wrms x 1 ) for bazooka 10"
and the T757 is running the 6.5" mids. 109wrm x 2
now my friend wants to trade me amps he wants both my class a/b amps for the
Alpine MRD-F752 Class T amp. which does : 114 wrms x 4 (4 ohms) @ 12 volts. + 389wrms x 1 @ 4ohm @ 12 Volts
Will i notice a difference between class a/b and class T amps in the highs.... also is it worth the swap.... I am mostly into SQ then SPL ... dont get me wrong i like things loud but it has to be crystal clear.
thanks
if you are happy with how your setup sounds now, simply say 'no thanks'.....you'll be giving up power/channels for either your mids or sub that way
If you are intrigued, and he is your friend-ask'm to let you swap it in to see if you like it.
Try it out. Tell him you want to test it out first. Install it and take a test drive. If you don't like it, your friend should understand.
try it out but honestly with the sub you have there it might not make too much of a difference more power yes, but not much change in tone prob. but ya def. try it out if u can then take it from there goodluck
grkstang
grkstang
nyc
MaXDout
