Need more trebel
Ok then if I'm only going to be getting speakers for the front then that give me more money to spend. So which out of these would you chose: JL xr, Infinity Perfect, Alpine spx, or MB Quart QSC? (if I left one out feel free to suggest it.)
Dude, I have a mid 140's daily driver and I recently popped in two Boston Pro60's, they are PERFECT! They handle the midbass great, are VERY accurate, and get louder than all hell, they keep up with the bass at every level and constantly amaze me, best $350 I ever spent, you know what I recommend....
By the way they sound better to me than Kappas, Focals, Diamond Audio, Pioneer, and a bunch of other things I have heard...
400x4 is way more power than you need, not to mention will most likely blow your budget out of the water //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Get a 100x2 amp. Run the rears off the head unit if you still need ambience, although with a powerful substage I'm not quite sure how you'd hear them, or why you'd even want to.
I havent decided on an amp yet, so suggestions on a good 400x4 amp would be nice.
How many wats should I bee looking into? I was thinking 100w per speaker, and a 400w amp.
I think when he said 400x4 he meant 100w per channel. I may be wrong though;)
wait how much you looking to spend on just the comps? also how much on amp? you can get a lower rainbow line for prolly 250 which will sound better then both of those sets. what kind of amp do you have running your sub? do you want the amps to match?let us know
My budget is 200, maybe a little more, for a set of comps. Then I will probably buy a set of coax. for the back, but I havent decided whether or not to run the back off an amp or just the hu. Then depending on the amp, the price will varry. Like if I were only going to be powering only the front then I would only need some where around a 100x2 at probably under 200, but if I ran the back and front of an amp then I would need some where around a 400x4 in which case I would be willing to spend more. If possible I wouldnt like to spen much over 500 grand total, on-line.
For a little more than what your looking to spend you can go with the Rainbow SLC's....amp those suckers and the money you would spend on rear fill either put into the funds you need to get the SLC's or roll it into the amp your going to be powering your frontstage with. Run the rear fill (stock) off your source.
ryanbssc29
ryanbssc29
Waveland, MS
ryanbssc29
